I have an '06 Bayliner 175 with a 3.0L mercruiser alpha one. Newly rebuilt carb. Twice, the inner part of the spark plug has been shot out from the same cylinder. The threaded metal stays put, all of the inner ceramic leaves, forcefully. The image shows the setup in that cylinder and the results.
The engine seems to be running fine for a bit and then there is a pinging noise for less than a minute, and then a gun shot sound. When I opened the engine compartment, I saw the electrode still attached to the burning wire on the floor.
Tense moment, but it worked out. Thanks in advance for any help, you and your knowledge are greatly appreciated.
https://photos.app.goo.gl/anbAmk1zijWEQyY87
