3.0l merc alpha one ?
samv119
I have a 05 bayliner 185 witht the 3.0l mercrusier alpha one drive. When ever i go to shut it down its kinda spits and spatters before it clonkes out. Is this normal? What could it be? how can i fix it?
thanks sam
JustJason
Re: 3.0l merc alpha one ?
it is not normal and can lead to serious damage so you want to get it corrected asap!
Your issue is called desieling
the most common cause is to high an idle....... but it can be many other things...
why don't you check your idle rpms in the water in nuetral and report back with the number
CJ
samv119
Im putting the boat in on saturday ill let you know the idle rpms. I was at the marine today and the guy told me i propably have cheap gas 87 octane in the boat. I dont know but the gas is from last year so im guessing its stale. I bought it this year and all the guy told me was that when he winterized it he put in fuel stablizer. thanks for the help
JustJason
the other thing you can do (especially if it's old gas), is when you come down off of cruise is to let it sit and idle for 2 to 3 minutes to let the heat soak burn off a bit before you shut down.
samv119
thanks captjack ill try to do that as much as possible. Its just hard when doing water sports.
Ayuh,....
And Water Sports will be Really Hard to Do,... After you Destroy your motor.....
Fix It,..... Or you Won't be Boating.... A Full,+Complete Tune-Up is a good start....
