Re: 3.0L Merc Winterizing Question
Yes, it is best to winterize with antifreeze. Some people use the RV stuff, but that doesn't contain anticorrosion agents. Some people use regular green auto antifreeze, but that is extremely bad for the environment. You should use propylene glycol with anticorrosion additives. I tried the "gravity assist" method with a bucket and hose exactly once, and didn't like risking the I/O pump impeller in my Merc 140. So I bought a winterizer kit that has a tank and a valve. You need to get the engine good and warm to be sure the thermostat is open, or do like I do and pull the t-stat for this step. Many people use the old method of pouring the antifreeze into the hoses near the t-stat housing, with the drains cracked open to confirm they are filling the block and manifold. Some people drain the drain plugs after putting in the antifreeze, but most experts I've talked to say to leave it all in there to protect the internal surfaces against corrosion. Of course, before all of this you need to heat up the engine, change the oil and filter, run it again to check for leaks and run the fresh oil through the engine. When doing the antifreeze through the pump routine, you want to fog the engine through the carb the whole time, then heavily just before the antifreeze is gone, to choke off the engine. Then I like to pull each plug and squirt a little Marvel Mystery Oil in each cylinder. I also spray all the metal components down with a corrosion protector--I'm now using Corrosion Block spray. These procedures are discussed in detail at many sites online--my instructions herein are just babbling--get a manual or find some detailed instructions you trust.
