Just had my engine serviced. Changed the plugs, cleaned carb, unstuck a valve and added a fuel filter in the engine bay, and replaced belts. Ran the boat a few times since then no problems runs great. Still running fine but noticed today that the temp gauge is showing 225. Pretty sure yesterday it was showing 175. Let the boat sit for an hour or so and as soon as it starts the gauge shows 225. I know it can't still be that hot. I can touch the exhaust manifold. Thinking it is the sending unit just wanted some expert input. Also, the alarm sounds with the key in the on position and the engine off so is it safe to assume the alarm is working? I am pretty sure I had the water pump replaced a year or two ago. Has only been in the water maybe 6 times in past few years. Any thoughts are greatly appreciated.
Thanks
Thanks
