3.0L Mercruiser (GM) cross-reference
anesthes
I just bought another boat. My first sterndrive.<br /><br />It has a Mercruiser 3.0/181 140hp alpha-1 setup. The guy who owned it had a head gasket problem, and rather than taking it to a mechanic attemped himself to destroy the motor.<br /><br />All the cyls are rusted now. Prolly froze. THe head he left _outside_ so the chambers are _ALL_ rusted. Valves do move, but it obviously needs work.<br /><br />Anyway. I spent the last two days trying to research this 3.0 block. Other than the fact that it is:<br /><br />181 Cid<br />9.25:1 compression<br />Uses 4.000 inch pistons (same as 350??)<br />Uses 1.94/1.60 valves (same as 350??)<br />Is 140hp in marine form, but only 88 in industrial<br />form.<br /><br />Since I can't seem to locate a local one used, at least for what I think is a resonable price for a long block (keep in mind I have everything else in perfect working order). I'm curious what automotive applications use the same basic "block". I know the cam is prolly different, and can re-use that but. There has to be SOME vehicles that use the same block/head design, even if the bore/stroke and valve sizes are somewhat different. <br /><br />What will bolt in? Get me through the summer anyway.?<br /><br />-- Joe
denniz
Re: 3.0L Mercruiser (GM) cross-reference
I have a 96 model complete $1200. but im in Texas.ROAD TRIP!!!!!!
ODDD1
Joe, there is no automotive equivalent. This motor is basically half of a 350 chev....industrial and marine use only...even if you do find a used one,there were many changes over the years, ie: 2 peice to one piece rear crank seal, with requisite crank change...a number of different cyl heads, differing comp numbers and different port/manifold hole sizes/locations....bite the bullet and buy a long block[by serial number] and you will have a shot at a reliable boating season.
Take your's to a Machineshop,+ Have it rebuilt....<br />a .030 over-bore,+ 4 new pistons....<br />Then you'll be Boating......<br />I've got 3 in the garage in varying degrees of "ready to run".....
mlslocks
ODDD1<br />There are automotive equivalents. They are just old. 60? chevy II, early 70's GM products and Some mail jeeps came with the IRON DUKE block. This was the 2.5 liter engine. The 3.0 is a bored and stroked version of the 2.5, 120hp
anesthes
I picked up a used one (1989) for 300.00 from a marine dealership. Its "as-is" but it runs, and may provide enough parts to make a "better than as-is" motor..<br /><br />Thanks for the responses.<br /><br />I'd love to get part #'s for the .030 pistons and rings. I can bore 'em to 4.030 in like an hour..<br />(I own a race shop). <br /><br />I guess I should dissasemble and see how close these pistons are in size, weight, etc to a sbc 4.00 piston. <br /><br />-- Joe
NAPA lists Std., .020, + .030 over pistons for the 140hp,By serial #s.... Page 371, in catalog # MSP-7...
ODDD1
yeah, the 2.5 /120 hp is the same as the old chev II motor....but is it the same as a 3.0? block the same? crank the same? head the same? just because it fits in the same space dont mean 'equivalent'...
mlslocks
as I stated bored and stroked 120/2.5. so stroked means different crank . Block is the same casting. Head may be different.
