3.0l mercruiser sputters and won’t run under a load.
The boat seems to run ok on muffs.
Changed:
Plugs and wires.
New distributor cap and rotor.
Carb was rebuilt and used spring loaded needle and seat, so I changed that to the solid needle and seat.
Checked timing and tried to run at 2 degrees before and up to 10 degrees before TDC.
Changed the distributor and coil.
Changed the wiring harness on the engine.
It seems that it is not firing on all cylinders but I checked and there is fire.
Thanks for your help.
Changed:
Plugs and wires.
