Fleetwin
- Nov 23, 2011
- 1,141
Hello All,
I have a 2009 Larson 18' Fish and Ski. I love the boat. It is very well built but a bit heavy. This will probably be the last boat I ever own.
It has a 3.0L GL-PJ with an SX Drive (32 hours). While adequate, the 3.0 is a bit cold blooded, noisy and generally just very old school. I've never been a fan of the old GM Industrial pushrod fours. I have some experience with 4.3's and they are an entirely different animal as far as noise, etc.
The same boat was availble with a 4.3L/same SX drive w/different ratio. I verified, with Larson, that the boat was the same regardless of engine choice.
I am seriously looking at upgrading to the 4.3L. Again, the boat is perfect for me and my needs. Money is really not the issue as I figure I can regain some expense by selling my perfectly good 3.0L Bobtail. Plus, I bought the boat far below value. I have a freind that can get me a good deal on past model V-P 4.3's. Either 190 HP (carbed) or 220 HP (EFI). Both of those would be Bobtails. I do realize that I will need a Y-pipe with connecting hardware, etc.
With all that, I have some questions:
1. I realize the drive ratios are different. Can I overcome that with Prop? I currently run a 19". It is the perfect pitch for the current 3.0 set up (decent hole shot and 4600 RPM WOT) with 40 MPH indicated GPS.
2. Are the engine mounts in the same place? My engine compartment is HUGE so there would be no issue with clearances or redoing a few things.
3. Are the two engines; 3.0 vs. 4.3 basically "plug and play" electrically? I can get a hold of the 4.3 installation manuals.
4. Other issues I may encounter?
Thanks.
Thanks.
