trevtt600
- May 17, 2009
- 80
Hello All. Took the boat for a ride with "new" motor today. Its a 3.0L mercruiser. Have an alpha 1 drive. At 2500 rpm when coming off the throttle i get a pretty serious vibration. It you try to cruise at 2500 same viration only not as bad. Seems like it is happening when the drive gets unloaded from slowing down. Just had the engine aligned, and the mechanic said the coupler is alittle worn, but should not cause any issues. Should i check or replace the u-joints? Any ideas i can check into?
