3.0litre mercury inboard coupler
Cc121
Having troubles getting my coupler off my flywheel, looked around and most people have the triangle coupler but mine is a circular one and can’t seem to get it out, anyone got suggestions
mickyryan
you mean the one that bolts directly to crankshaft? what is issue the bolts wont come loose?
Chris1956
You should repost this in the MerCruiser forum. Those guys are experts.
Ayuh,..... Welcome Aboard,.... You took the 6 nuts off the studs, Right,..??
If so, with a BFHammer, 'n a block of wood, give it a few taps,....
mickyryan
its probebly siezed to the driveshaft might need to tap with a hammer if i recall it has a center piece that aligned it and they get stuck sometimes shouldnt need much persuasion if all bolts are out
