I recently replaced the alternator in my 3.0LX mercruiser I/0. I replaced it because even though I had 2 brand new batteries installed (on a 2-battery switch) after taking it out for a while I heard my depth finder's battery alarm going off and noticed I was only running 10-11 volts. So, after replacing the alternator, I took it down to the boat ramp and was pleased to see I was running a more normal 13 volts. So, off I went into the bay only to have the same problem occur again about 15-20 minutes into my trip. <br /><br />This happens no matter which battery I run on. I have heard to not switch to "off" while running engine, which I have never done. <br /><br />The only two things I can think of are A) my "new" alternator got zapped by some loose wire possibly? Or maybe something else? or B) there is some corroded cable somewhere, but I have no idea where to look for it. The alternator is a 3-wire system with a 4th wire for ground.<br /><br />I'm new to the board. Be gentle!
