3.6 Merc. - Dies after wide open throttle
OhioPaul
I picked up a little 3.6 Merc last fall that would not start. I found the compression to be only about 30 lbs. I took the motor apart and found broken rings. After honing, cleaning, new rings, bearings and reassembly, it fired right up. I ran it at different speeds in a barrel for about an hour total. This weekend it was finally warm enough in northern Ohio to put it on my inflatable for a spin around a local lake. Now I have two questions. One, I had to put my hand over the carb. in order to get it to start. It did not seem to matter if the chock was on or off. Two, While running around the lake, I increased the throttle about every 5 minutes until I hit wide open. Now, when I cut the throttle back after wide open, the motor would die out and I would have to start the motor with my hand over the carb opening. I could idle back at 1/4, 1/2, and 3/4 throttle without any problems. I shut the motor off and it would restart without my hand over the carb. at the 3/4 or less throttle. The engine ran and sounded great at all speeds. It would run wide open without any problems until I throttled back. Any thoughts on the way too long of a question?
Darryl34
Re: 3.6 Merc. - Dies after wide open throttle
I have the same motor.I have not had this problem with it,but my suzuki 6h.p. was doing the same thing.Did you tear the carb down and clean it when you did the motor?This should clear the problem,also what mix ratio are you using? 50:1 ?
OhioPaul
Yes, I have the mix at 50:1 - I did take the carb. apart to look inside. Everything was spotless. I did check the float setting and it was correct.
Darryl34
what year is your motor
OhioPaul
Still looking for help. Any suggestions???
Kenny Bush
You guys check the fuel delivery system. Hose, bulb, fuel pump diaghram, carbs.......... I would check the fuel pump.... post back...
OhioPaul
This engine has a built in tank. It is all gravity feed. There is no fuel pump. I have replaced all of the fuel lines and the in-line fuel filter.
OhioPaul
I am Still looking for ideas on this topic.
