searcyfarms
- Mar 6, 2013
- 31
Greetings All,
So, the famous pitted camshaft has finally gotten the best of me.....I have attempted the speedi sleeve repair only to last a couple yrs then back in same boat pardon the pun......I know the boat is old, an 82 or 84 cant remember. Its a 488 - when running runs great - Boat is a one owner - been kept inside so its in excellent condition so that is the ONLY reason I am looking to attempt repairs. At this point its a paperweight. SO - do I need any special tools to get the thing apart, any notables to be aware of regarding tearing down to get the camshaft out?
I have taken it down this far 4 times now replacing camshaft seals pulling the harmonic/stator thing off the crankshaft with a puller, blah blah so I am at least good at tearing that piece down.
I am aware of timing of cam/crank things in engines, I know the distributor will probably have to come out? Try to make note of that of course.
I have taken apart a few car engines back in the late 70s/80s and replaced parts but this seems a little daunting/overwhelming for some reason. There seems to be lots of big chunks of intake/exhaust/water tank manifold thing, shifting cables look overwhelming with those and wires. I have found a water pump gasket kit.
I found a couple camshaft kits with lifters. I only see two offerings of camshafts/kits. Before I indulge and bite the bulled I want to get the dang thing apart to see if I think I can get the thing back together. I am concerned that bolts may not come out and I break things. Yes I am in over my head but hate to spend 3 grand for a replacement engine and don't think I could that either.
SO....I see panther sales and falcon marine make the camshaft kits, I know NOTHING About either place but due to all the failures of the original camshafts and pitting I sure as the world wont be putting in a used one. Do any of you have any experience or recommendations on camshaft kits for these engines? panthers or falcon longevity, reliability, are they an oem grind?
I also read something about how the end of the camshaft is made and the impeller mounting etc.... mine is a ground end with two squared off sides and internally threaded end that a bolt w/washer goes in that holds on the impeller has that changed?
I only put about 20 to 30 hours a year on my boat so it doesn't get a lot of use. I presume manifold gaskets are available ? I am going to need various ones obviously - no clue just what yet but presume both intake/exhaust - head - that huge water manifold thing where it bolts to the engine - any other ideas what I might need, does anyone sell a kit for that stuff?
How about all this shifter stuff - cables/wires, can I leave it intact and just take the entire bracket off and leave it together and set it aside?
I live in the Kansas City Missouri area so anyone that wants to help C'mon over LOL!!!!
Thanks in advance for any advice/info - is there a good book that you would recommend for taking this thing apart and getting it back together?
Robert
Robert
