3.7 ltr problems
captgarysr
have a 3.7 that starts and runs great up to 3200 rpm, pushing throddle slowly after that will go up to 4000. but if throddle is pushed quickly at 3200 it will die out, unless you pull back on throddle letting recover. have replaced carb with new one , new fuel pump, hooked up to portable tank timing good plugs new wires new has electronic pts, new coil. any ideas????
crazy charlie
Pull the dist cap after it happens and look for moisture buildup inside the cap.Had similar a while back.Charlie
Ayuh,..... You replaced the carb, but have you done proper set-up of the carb,......
My guess is, the accelerator pump needs to be richened up abit,....
