3.7 mercruiser
Corvette1982
Hello: Can anyone direct me to info about setting valves on 3.7 engines. I have been told one must change the push rods. Thanks
nola mike
Yeah, they're not adjustable. You need the factory service manual. What issues are you having?
kenny nunez
Pull the valve cover and and check for a loose rocker arm, you will have to bump it over to check them all. Hopefully you do not have a worn out cam lobe caused by the lubricants that do not have the zink additive.
i second Kenny's comment on the cam lobe
