grady86
- Feb 19, 2014
- 32
I have a 3.7L Mercruiser Alpha One, year 1989, 165 HP, 224 CID. 2 barrel carb, pointless distributor ( see picture ). As of right now, I am not getting any spark, even with a brand new rotor and distributor cap. Backing up a little, the motor recently went from running great to not running at all, i.e. no spark at any spark plug, so I checked under the distributor cap and saw the rotor was destroyed ( see picture below ). After replacing rotor and cap, the no-spark issue still remains. I used a strangers' advice and used a wooden dowel to check the #1 spark plug's top-dead-center position in relation to the rotor position. Although this didn't seem to be a very exact method because I'm not sure how to know which is the exhaust and which is the compression stroke, the rotor was pointing directly at the #1 spark plug position on one of the two top-dead-center strokes. Another bit of information is that the ignition coil is sparking normally on the high tension lead when grounded to the engine, although with the ignition switch in the on position, the coil gets ridiculously hot for some unknown reason... not sure if that is normal, but I don't remember it ever doing that before. Thanks in advance.
Sincerely,
Grady
Sincerely,
Grady
