Re: 3.7l mercuiser alpha one
Pan,Is this leak with the motor not running?Best thing is to remove that end plate,hammer it flat,reassemble with a new rubber gasket.Do the other end plate also.If leak still continues,probably internal cracks in the heat exchanger.<br />DHP
