longstand
- May 2, 2009
- 293
HI...
iam having problem with my tilt.. i have check the worm gear. fill it up with greese and made sure its connected to the motor.
remove the clutch and clean it up.. and fill it up with greese.
i put the cover back and made sure i put gasket so it will not be to tight the clutch will not engage.
i replace the tilt motor.. still wont go up or down.. sometimes it do work but having hard time ...
i made sure all gasket is install where it need..
I been having this problem for a long long time.. i have remove the clutch and worm gear so many times. and i cant figure this out...
I also try to remove the Sterndrive off Spur Gear so there will be no weight.. and it work.. iam thinking the the sterdrive is to heavy.. LOL
Please Help
Please Help
