trooper1822
- Mar 2, 2013
- 65
Ok so I am starting a new thread now that I have the motor put back together and am at the point of trying to start it. Engine is a 81 3.8l. What I have done so far: has new starter, new battery, new plugs and wires, had ignition coil tested and its good, checked spark at wires and am getting spark on all wires, fresh fuel being pumped from my 2gal gas can, replaced fuel filter, did compression test and it was good. I tried testing to see if the pump is pumping fuel by disconnecting the tube at the carb and observed it shooting fuel with great force while cranking. Disassembled carb and cleaned everything. I put the engine at TDC on the compression stroke and aligned the distributor pointing at the number plug. The engine will turn over but not start. It sounds like it wants to start and gets very close but just will not run. I have tried using starting fluid and even a little raw fuel into the carb but still no go. Also tried pumping the throttle a few times and then trying to start but no change. The only thing I am wondering is the previous owner had a motorcraft coil installed on the engine and when I went to have it tested they said it was good but motorcraft is a ford part. Do not know how much this affects things. Any advice on how I should proceed? Thanks
