Re: 3 bank battery charger
I haven't heard of anyone with the Opticharge. I have a Guest Charge Pro 2613 for my 24V trolling motor, and it has a third bank for the cranking battery, and it works great! The Opticharge looks like it "only" puts out 4 amps per bank, so it probably depends on how often you use your boat and how quickly you want it to fully re-charge your batteries. The Cabela's ad doesn't give a whole lot of info about the Opticharge, so I can only assume that it has similar "smart" circuitry as the Charge Pros? If I were you, I'd probably look at a 2631 Charge Pro that is designed for a 36V system and has higher output. It may sound very expensive (almost 3x as much!), but trust me, after you've used one for a while you'll wish you would have bought one years ago!
