jkimball
- May 14, 2013
- 220
'99 FW Horizon 170, 115HP Johnson V4
14x19" Aluminum (Factory OMC)
5000-5100 RPMs @ 39-41 MPH WOT with normal load
Stingray Starfire Hydrofoil
Prop Blows out in semi-tight turns,
Boat falls on its face in turns with a tube behind it.
I want a better riding boat, with good hole shot, good cruise, and I don't want to lose too much top end. Most of the time I don't go WOT for very long anyhow.
5000-5100 seems low considering my WOT suggested is 4500~5500 RPMs
I am highly considering Solas Amita 4 blade, 12.75x17P. I realize that going down in pitch should increase my RPMs, but not the same as going down in pitch with a 3 blade as the larger surface area will decrease this.
Is there any reason I should not consider a 4 blade?
Mainly use the boat for crusing, tubing, and occassionally have max capacity of 6-7 adults/ teens.
It seems a 4 blade will, especially lower pitch will give more efficiency & "power" in the range I use it.
