jkimball
- May 14, 2013
- 220
'99 FW Horizon 170, 115 Johnson with 13 3/8 x 17" Stainless. (recenly put on)
Originally had 14 x 19" Aluminum.
When I changed from the 19" aluminum to the 17" Stainless, I gained around 500 RPMs, now at ~5,500 at WOT
I ALSO picked up about 4 MPH WOT.
Currently under normal load, with full tank I am getting 42 MPH @ 5,500 RPMs with hole shot much improved.
The OEM Spec book called for a 19" aluminum and 41-46 MPH. So, with the 17" I think I'm doing alright.
However, this prop vents pretty bad in tight turns, and I would like to eliminate that, and I've always loved the idea of a 4 blade prop.
But, I don't want to lose anymore top end if I can help it. So, if I went with a 13 x 19" Solas 4 blade, what could I expect?
The diameter is smaller, so would that account for the increase in pitch for RPMs?
And by increasing pitch, would my top end stay about the same/ increase?
The 4 blade 19" holeshot would be better than my old 19" aluminum's, but how would it compare to the 17" stainless 3 blade?
To sum it up
1) adding a blade
2) increasing pitch
3) decreasing diameter
To sum it up
1) adding a blade
2) increasing pitch
