I have obtained a Mercury 1987 60hp 3cylinder that had been submerged and the block is shot.
I also have a late 70's 3 cylinder 70hp block, which I would like to use as a replacement. (for those who don't know: Mercury went from crankshaft HP to propshaft HP in the mid eighties and the 70hp became the 60hp)
I can't find the serial number on the older block, anyone know if/where they stamped the numbers?
I'm trying to ascertain the differences. I was surprised to learn that they installed thermostats in the older 3 cylinders, but omitted them after around 1980.
They also changed the firing order from 123 to 132. I will have to be careful wiring the switchbox.
Anyone have any insight on other issues? Can I omit the thermostat?
