anthonybradley
- Aug 12, 2007
- 6
Hi, have an early - mid 80s Yamaha 40 autolube (3cyl 2 strioke), was serviced start of year, and been running fine, but now running rough / stalling at idle etc.
Long story short it will run ok just cyl 1 or just cyl 2, but on just cyl 3 it splutters and stalls, and produces white smoke, all 3 cylinders together it runs a bit better but still rough and some white smoke, so def seems to be cyl 3 at fault. Done a compresion check and all ok, cleaned / swapped plugs and checked spark etc. Have stripped #3 carb and cleaned it, but it didnt really seem to need cleaning anyway and fault still the same. Fuel seems to be getting into cylinder as plug is wet if disconnected. All linkages are free and easy, and not been moved since last working ok.
Any ideas? I suspected head gasket, but compression check is ok. Checked fuel pump and supply but they must be ok anyway as other cylinders run ok.
Anys and all ideas welcome
Thanks Anthony
Thanks Anthony
