Boat Specs:
2000 Larson SEI 186 w/ 4.3 GL PEFS 4012004502
Problem:
Boat runs perfectly, then will completely die and not restart, as if it is out of fuel. I pour fuel from a 5 gallon can, and get about 3 gallons out and the tank is full, to the point of overflowing. The boat takes a few cranks (assuming fuel pump is sending gas thru empty lines), then fires right up. After heavy usage pulling skiers, it dies again after about an hour. I add 3 gallons of gas, and it cranks and fires right up, then dies in an hour. Its like I have a 3 gallon size gas tank.
Additional Info:
My fuel gauge does not work, suspect a faulty sending unit, but the boat is docked and I have to remove the seats to access the gas tank to change the sending unit. I will do it in a few weeks when the season ends.
Any ideas why I have to add gas every 3 gallons?
Thank you!
Problem:
Additional Info:
Thank you!
