Looking for some advice on a 1965 3 hp 2 cylinder light twin carb adjustment. There is only a single low speed adjustment, and i have set it at 1 and a half turns out, but the motor won't stay running unless i fiddle with the choke. Unless it is about halfway out, it won't run and periodically i have to pull it almost the whole way to prevent it from dying. Can't really set the carb properly until i can get it stay running....
I've re-done the carb kit (needle packing, high speed nozzle etc), blew out all the passages with carb cleaner, including pulling the core plug out. I've also been through the ignition system and replaced condensers etc. I really want to get this thing running so i can move it along to pay for getting its twin (i have two of these things, the other is in pieces on the garage floor) going.
Thanks in advance
Thanks in advance
