Re: 3 or 4 blades?
The guy's here take this far more serious than you might imagine, If you can or would post you you spec's at wide open throttle, rpm and speed it would be easy to dial a prop in for you.
Now if you simpley want a prop that can lug a lot, sure a 4 blade will work better than a 3 blade. But that is so generic and misleading to a 4blade prop most dont want to give a answer.
I want my big (24') Jonboat to PULL at slow speed. 100 hp merc
If that's all you want get a 16 p 4 blade problem solved, but dont speak of all around preformance, your getting what you asked for
