3 Questions: 1. can you tell if i have a staggered bolt pattern, 2. what type oil
bamafutbal
1. is this a staggered bolt pattern or the straight mount on the starter
2. what type oil filter is this and do i have to use this model (wix) or can i get another kind, couldn't find wix for sale on iboats store (if so what model # filter)
3. identify that part by the oil filter with the purple wires going into it. its appears all rusted out and i want to replace it
thanks
john
1999 blue water monte carlo v8 305 engine # 0L080844 (alpha)
By bamafutbal, shot with DMC-TZ5 at 2009-03-08
JustJason
Re: 3 Questions: 1. can you tell if i have a staggered bolt pattern, 2. what type oi
1. yes its staggered
2. go to a Napa autoparts store. Napa labeled filters are Wix.
3. oil pressure switch... do you have an electric fuel pump?
betayv
hi there that is a NAPA # 1069 napa gold and check the starter with this people they have good prices and new stuff http://spidermarine.com/
bamafutbal
i have a carb's model. so should i replace the switch beside the oil filter?
By null, shot with DMC-TZ1 at 2008-01-03
JustJason
doesn't matter if you have a carb or not.... Do you have an electric fuel pump?
If you do, and the pump works... then leave the switch. If you do, and the pump isn't working, replace the switch.
If you don't have an electric fuel pump... well then it really doesn't matter.
bamafutbal
no idea if i have an electric fuel pump, i am just wanting to have a little preventive maintenance.
chiefalen
I use DBelectrical.com for starters and alternators, he is on e-bay and has the best prices. Lost count of how many different things i bought from him and has great service. Me i would send him a email or go to e-bay and order one from him comes with new bolts.
The other parts you want to replace can be ordered from this website, or :
http://www.crowleymarine.com/brp_parts/7087.cfm
http://amarket.com/omct.htm
Just 2 of the many, many places to order from, crowly has OEM and Don s posted that website and i like it alot for the diagrams.
Good luck !
Ayuh,...
Go ahead and swap out the switch,...
If you have the switch, it's a pretty solid Bet that you have the electric fuelpump....
betayv
the switch in the pic if for the oil pressure? what have to do this switch with the fuel pump? Im sorry but I have to ask thanks guys!!!
bamafutbal
so starting over, what is that little rusted out switch with the purple wires going into it? want a little preventive maintenance since my head and hand will be down there changing the WIX oil filter
captk
The switch is for the warning horn.
Ayuh,... It's Still an Oil Pressure Switch....
180shabah
The oil pressure switch is for the electric fuel pump. With the key in the run position, power is routed through the switch. No oil pressure, no fuel pump.
It is a safety feature and is USCG required.
captk
no electric fuel pump on that engine
bamafutbal
and the consensus is....
JustJason
Winner winner chicken dinner!!!!
Bonk again......
According to the serial ## it should have an electric fuel pump.
In fact its part number 861155A3
180shabah
Yup - the purple/yellow wires cary 12v+ to the fuel pump.
If it was audio warning system the wires would be tan/blue.
Can I get extra skin on my chicken???
chiefalen
So it goes like this when you turn the key and start the boat the switch with read is you have oil pressure no oil pressure within 3-5 seconds it shuts off the fuel pump.
So if it runs ok starts ok then you really don't have to mess with it.
Me if the starter just looks rusted i would paint it, if it starts ok runs ok then why mess with anything, till you break something.
I don't know if it runs ok starts ok or whats what just a little advice that you didn't ask for.
bamafutbal
went to my local boat stealership today and ordered oil pressure switch (87-86425A01) and the black thing besdie it is a sender (#87-815425T). as far as the starter goes it has a staggered bolt pattern and will probably get the arco starter for $180:mad:, have not been able to find it cheaper
