3 starter solenoids EDIT figured out!
catfishcarl99
any ideas why this 115 evinrude needed 3 of these? was on a bass boat previously. on a toon now. i want these 2 on the rear gone so i can replace my exhaust cover gasket thats seeping oil. i unhooked the large positive jumper that ran from the orig solenoid by starter to the two in the rear. still turns over. can someone help me strip this un needed wiring. i just dont want to mess it up. why would a motor need all this??? i dont even understand why.
catfishcarl99
ok so after some inspection the rear ones are running the trim tilt which i assume is not original.
Ayuh,..... Why would you assume that,.....
The trim/ tilt wirin' has to go somewhere,.....
