I have a 17' power catamaran, the prop sometimes slips due to cavitation and ventilation. I need a 4 blade prop.
My current prop 3 blade 14x17 (size: Size 13 7/8 x 17) is good for the boat I have, WOT gives me 5250 RPM@29 MPH with only me onboard 200lbs. Engine: 2001 johnson, 60 HP, 2 stroke, 3 cyliders. RPM range in manual states 5000-6000. I use the boat for fishing crusing it is a fiberglass center console. Weights aprox 1200lbs with full gear NO passengers.
The prop company im interested in told me I should use their 13x18 4 blade prop. This doesnt seem right, Im no expert. The prop measures 13" exactly. Im dropping down 7/8" in prop size, gaining 1 pitch and gaining a extra blade looks like I will drop to 5000 rpms?. Does this seem right?
The other choice they gave me would be their 4 blade 14x18. this seems it would drop me right out of my good power range instantly.
Here is the same boat setup by another dealer with a similair sized engine.
http://www.budsoutboardmarine.com/uploads/60_performance_report.pdf
Thanks in advance for any input.
