1983 260 mercruiser sat three cold central NY winters in a row.2000 season was the last time the boat was run. Ran top notch, was winterized before lay up.Due to really depressing circumstances boat and I were strangers.When I went to the marina and tried to start the motor(I was trying to be optomistic)she would not turn over (no kidding).At this point I had her blocked up in my driveway and checked all the usual everything looks ok.I pulled the spark plugs and tried to turn her over with the starter (good battery)to no avail.I then sprayed some WD40 in the spark plug holes and let her sit over night.When I got home from work today I tried her again, nothing .I put a socket on a breaker bar and could not budge it.I did'nt want to break the balancer bolt and have that to fix too so I did'nt really put the wood to her, if you have ever left a half of a bolt in a crank you no what I mean. I then used a piece of tubing and poured Marvel Mystery Oil in each cyl.How long do you estimate it wll take to free this thing up?How can I put some more ass to the rotating assem. to turn it? Is it junk?
