have a 1999 30 hp ele start have dismanteled an cleaned the carb also the fuel pump because the engine started cycleing up and down when i opened up the throttle. there are no fuel leaks compression is great new plugs fresh gas idles like a kitten. this happens intermitintly after ive been running a while then it only runs at low speed. give it a while and crank it up and it runs great again until the next time. ive checked everything i can think of to no avail. any ideas?
