How do you bypass the RPM limit module ?
B bighh7 Seaman Joined Sep 13, 2011 Messages 53 Nov 6, 2011 #1 How do you bypass the RPM limit module ?
Texasmark Supreme Mariner Joined Dec 20, 2005 Messages 14,786 Nov 7, 2011 #2 Re: 30 hp Merc Try just disconnecting it. It probably grounds out your triggers when you exceed rpm's. Engine MIGHT not start, but other than that you ainna gonna hurt nuttin, I wouldn't think. Mark
B bighh7 Seaman Joined Sep 13, 2011 Messages 53 Nov 7, 2011 #3 Re: 30 hp Merc Thanks for the reply , does the ignition system not run through the TPM ?
