30hp 1989 yamaha firing problems?
sambrigman
this motor starts rite up runs perfect until i take off, runs fast and smooth for about 5 minutes then suddenly looses power and runs like it is about to jump off the boat. Anyone run across anything like this? Maybe electric? gas? any suggestions greatly appreciated
check your fuel system. grab the factory manual and start troubleshooting
99yam40
over heating or low on oil (if it is an oil injected motor) will put the motor into RPM reduction mode to let you know the motor has a problem just in case your buzzer/horn and gauges are not working properly
airshot
Does the squeeze ball in the fuel line remain hard or does it go soft ? Try squeezing the ball and see what happens when it acts up. How old is the fuel line ?
Need more info to make suggestions.....
