To racerone & Crosbyman, I pulled the flywheel, came away quite nicely, thank you racerone. The coils are the familiar green style seen on many vintage (and not so vintage) OMC engines. Couldn't tell if they were original, but they appeared to be (physically) in good condition. The primary winding measured about 0.5 ohm with a Fluke 29. Pretty good meter, though I prefer an old Simpson 260 - but a 260 won't accurately read such low numbers. From what I've read, this reading (0.5 ohm) is a bit low. Some say 1 to 1.5 ohm is more common, but I hesitate to condemn the coils yet. The secondary from the hi voltage pin to either primary wire measures about 3200 ohms, typical from what I've read. I could have sworn I read open circuit from the spark plug connector back through the plug wire to either of the primary connections (not the 3200 ohm, as should be) - but upon rechecking, all was correct. These appear to be actual wire type plug leads - not resistance wire. The points look ok and functional. I've got to go out of town for a couple days, so I'll check, clean and set the points perhaps this weekend and see what results, and let you guys know. Thanks for your help.
