35 horse force compression
ddoby
Can anyone tell me what to expect the compression for a 35 horse force to be?<br /><br />Thanks
WillyBWright
Re: 35 horse force compression
On my gauge I'd want to see between 100psi and 120psi. Gauges vary. I'd also like to see no more than a 15psi difference between the two. Let it crank over about the same number of times, at least 5 strokes (I usually go for 8). If you're pulling it over by hand, look for about 20psi lower readings.
WhiteHorse
I like to see 120-125psi on each, and no more than 10% differential.
