rolmops
- Feb 24, 2002
- 5,540
So I got back into playing with outboards a little bit.
I have a 1986 OMC with CD2 power pack. The last time this thing was run, was for 10 minutes in 2003 in Cape Cod bay and pulled off the boat because of a lower unit problem. (it kept on dropping out of gear). Next it spent 17 years in a barn. I got a hold of it, replaced the impeller, did a pressure test (115 in each hole)cleaned out the carburetor, replaced the fuel pump and hoses,replaced the plugs, spark plug wires and checked for spark. Next I tried to start it. The engine turns over nicely, but does not start. I am inclined to replace the cd2 power pack and the coils, but I wonder if this is neccessary. It says that it must have the ignition at 34 degrees advance, but I cannot find an adjustment screw, and I do not even know what to adjust.
Any help is highly appreciated. Thank you.
