35 hp ignition wiring
smorris
The motor is a tiller steer model 35r76g with electric start. It has the following wires:
large red and brown or purple-I know these are for the starter
small red from hot side of coil
two small black wires attached to blue wires attached ignition coils
white wire from ground on starter coil
The wiring harness was cut when I got the motor. Can someone please tell me how to wire a new switch
Thanks, smorris
tashasdaddy
Re: 35 hp ignition wiring
here you go
smorris
Thanks for the diagram but what I have seems to be quite different. I guess what I am asking is how do I stop the motor from running? Am I correct to ground the two wires coming from the ignition coilsto stop the motor or is this stupid and will it fry the coils?
The motor is a tiller steer and I am planning to place the ignition and start button on the front of the motor beside the pull choke
Thanks again
