Miller_Time
- Mar 19, 2003
- 18
Well, I've got problems again. When I first bought the boat, the motor would crank and idle fine but would not run at full speed. I cleaned the carb, put a kit in and ran the boat several times and the motor ran great. Took the boat out today and ran into another problem. While running at 3/4 throttle I felt what seemed to be fuel spray on my leg. Never found where the spray was coming from. Then the motor started cutting out and died. After trying to start and restart the motor, it wouldn't stay running. Looked as though the fuel line connector from the tank was loose. Took it off and on, primed it and cranked again, and it would run as long as it was choked. Got home removed and clean the fuel filter at the fuel pump and still will not run unless choked.<br />I know it could be several things, but can anyone help me out?
