sunburnt
- Jan 21, 2007
- 67
hi , i have a 1985 35 hp 2 stroke merc .had good compression , was knocking so i split casing! lower bearing fell out definatly have to replace lower bearing -bearing retainer- bearing clip .my ? is the reed has alot of slop in it must have been what kept it moving . is there just a bearing for this part or do i have to get whole main reed cage? $$$$ reeds are great ! also some play side to side on wrist pin bearing is that ok ? upper bearing good - will replace seal.these lower bearings had a plastic bearing holder only thing left inner and outer of bearing gone was this original? thanks in advance for ur reply! sunburnt
