350 Mag / Alpha One / Gen One Gimbal ring bearing seals
Brando33
I have the SELOC Sterndrive book for Mercruiser. It’s telling me to install the lower gimbal ring bearing seals “Both” facing up. This doesn’t seem right to me. Between the seals is a needle bearing that has a Zerk fitting. The only thing I can think of is the bottom seal will act like a relief for the grease instead of popping a seal out.
Brando33
You have a knee pad at best. A fire starter is what I call seloc. Toss it and get the factory manual.
So the factory manual says otherwise?
At the time this is all I could find. Wonder where I could get one.
Drivewayboater2
I believe you need the #6 mercruiser manual For aphla 1 gen 1. Found mine used on eBay for $25.00
Drivewayboater2
Here’s the cover of the service manual followed by the pages describing the seals…. Early model alpha and later models.Hope this helps. Happy new year!
Brando33
Thanks. I’ll look for one. Weird how there is no mention of orientation of seals.
Brando33
542D77BB-7A85-4D60-9D1C-1112F57EF531.pngWell I did a search for the #6 manual and was able to find a free online one. Attached is a pic for those who care. It does require that both seals are oriented with the lips up. Thanks drivewayboater.
