Makes sense. So do you think it would be possible that one of the check valves on the bottom of the exhaust manifolds has failed and is draining off pressure to the water mixer?
And to go with the IR temp gun testing here could be some similar specifications to compare against for both normal and running hot.The IR temp gun would be good to find out where all of the hot spots are.
