35hp 1976 Johnson
magott
Hi. Just bought a boat with this motor (35el76g) electric start.Have found a 35hp pull start on sale for $50 with lower unit problems.My motor goes but other than test firing has not been used for 2 years.As I know nothing about outboards, thought it may be a good idea to buy it and pull apart just to learn.I have an original manual purchased on e/bay.Would their be enough interchangeable parts between these two motors,and do you think it would be worthwhile.Thanks.
blimp
Re: 35hp 1976 Johnson
Getting a parts motor for $50 is always a good idea. Your motor is 34 years old, and parts will go bad/wear out/break.
Some advice though, the manual has enough info in it for you to get to know your motor plenty well. I would get the parts motor, put it in a corner in your garage, and use it as needed for troubleshooting and replacing parts. you can drop the lower unit, investigate what is wrong with it, and maybe even have a 2nd working motor if it is something simple!
A motor in pieces is just that, parts in a box. But a complete motor is a great reference in case you want to try a repair out or just reference what things are supposed to look like when you get too deep into fixing yours.
my 2 cents.
magott
Your 2 cents makes a lot of cents.Will go that way.Thanks.
