I've been having problems with my 96 Evinrude 3 cyl. Last week, it would start and stall every 30 sec, had a hell of a time getting it going. Finally did, and ran high speed for 15min until I put it back in the lift. <br /><br />Next day, wouldn't start at all. <br />Day after that it would start and sounded like it was only running on 1 cylinder. <br />So I brought the trailer down to the ramp, and had a buddy ready to tow me. Got it fired up and actually running. Had to run a mile up stream, and finally made it, but stalled and had to restart a few time. <br /><br />Home in the driveway, I started to go through things. Good compression in all 3 cyl. Good spark. Cleaned the carbs, and they were all spotless. Fuel pump is working good. Fuel filter was clean. Plugs looked good and were gapped correctly. Tested everything else that I could (that I have the knowledge to check), cleaned all applied dielectric grease to all connections. Never found anything that looked like it would cause the problem. <br /><br />Fired it up on the hose in the driveway, and it seemed fine at idle and slightly above idle. <br /><br />Trailered it back to the river and put a good hour of running on it without a hic-up. Turned it on and off many times, and it fired right up each time. Forgot to open the vent on the fuel tank, and it sucked it in enough, that I know the fuel pump is working great. <br /><br />So, the good news is, it seems fine. The bad news is, I don't trust it, as I never found a problem. <br /><br />Any ideas?????? <br /><br />I hate to take it out, and worry about it all day long. Takes the fun out of fishing. <br /><br />Thanks for any suggestions, <br /><br />FishHog
