1) like an idiot, i forgot to winterize my johnson. got a new gas tank, put 3 gallons of gas and 50:1 oil ration like always. everything is connected right.
prime the bulb, pull out the choke and the motor will start up fine, run a couple seconds then suddenly die out. there was a little gas laying under the carb when i took the cowl off...
what could be causing this, i was thinking maybe the needle is gunked up and sticking, causing the carb to flood and die. thinking maybe spraying some carb cleaner in to see if it cleans out some possible varnish...
2) ALSO, while trying to crank it, the ignition stuck and keep trying to crank, took the neg cable off the battery and touched it to the battery and it started trying to crank, what could be causing this?
