35hp wiring problem
I am using an after market ignition switch and I need to know how to wire it. When I wired it the motor started fine but it would not shut off. There are three wires from the switch (batt, sol, and ign.) can you help me?
achris
More fish than mountain goat
Re: 35hp wiring problem
Modern ourboards don't remove power from the ignition, they ground a kill wire. That's why you'll need to go and get an OEM ignition switch. It'll have a few extra terminals on it. One for ground, one for the kill wire and one for the choke.<br /><br />Chris............
kentfa
So the third wire will kill the motor if its put to ground? i Wonder becouse i have the same problem, a brown wire that is used for nothing(maybe to prevent starting in gear?)
