RPJS
- Jul 29, 2002
- 1,572
Model #JW18R<br />Serial # B65288<br />Can anyone help<br />I found the above motor when clearing out my farthers garage, I do not know how long it had been standing for but it must be several years.The motor was not seized when I found it but was fairly tight when turned over. I removed the plugs and filled the pots with WD40 and left to stand for 3 days then by very gentle movement of the flywheel I freed the motor off and it now turns over very smoothly. I have also removed the carb and fully cleaned and blown thru all jets etc. I removed the magneto plate and cleaned the points, the green insulation on the coils is cracked in places but I get a very good blue spark on both plugs. I do not have a compression tester but this seems to be OK when I turn the flywheel by hand.<br />The problem is that the motor will fire and run OK with the choke 3/4 closed however if I try to open the choke fully it just dies, this happens in all throtle positions.<br />Any sugestions please<br /><br />Many Thanks
