Hi all,
My 3L with cobra outdrive is shifting pretty hard. I shift with a firm, fast movement--no grinding. It's a pretty hard thunk into gear that you can feel, not just hear. Neutral idle is a touch above 700rpm. I've read 550-600 is ideal.
My idle stop is adjusted all the way out and it still sits there.
Is it safe to play with the mixture to try and bring it down? Do I need to rebuild the carb? Anything else that can cause this?
Thanks so much. I really cannot afford a new gear set!
