I've run into a problem with my 1988 merc. 4.3 185hp. It starts perfect on the 1st crank if it has sat for some time (overnight). It idles fine and runs smooth. The problem is that when I cut the motor after its warmed up and try to restart, it just cranks over as if there is no spark. The starter works fine, and its getting gas(carb rebuilt last season, doesn't seem to be a problem with the choke). It just cranks and won't fire. It happens randomly not everytime, but when it does happen it won't start for about an hour. When it doesn't happen, the motor fires on the 1st crank. The wires are pretty new, the cap looks good, I haven't checked the plugs yet but since it runs very smooth when started I don't think they are the problem. Any insights, suggestions would help. Thanks.
