4.3 auto vs marine heads
bauerterry
I need help, i had freeze damage and a cracked head and got my questions answered here....so here goes i hope someone can help.....i have a 2001 volvo 4.3gl....will auto heads work and just be able to bold on, and what years will work, the motor is a vortec, i assume i need vortec heads....or will other years work....also am i safe if i just match the casting numbers on the head....one last thing, does anything need to be done to the head, ie valve job or anything like that.....thanks
bluewater19
Re: 4.3 auto vs marine heads
The heads are the same as a gmc 4.3 pickup/van/suv of the same year.<br />you need 1996 and up. check that they have the vortec intake bolt pattern. <br />If they are very used a valve job might be a good idea.
Ayuh,..................<br />That's about what I just posted on your Other Thread..................<br /><br />Good Luck........
bauerterry
sorry bondo, didnt know if people read the old messages so i posted the new one....the motor is torn apart, the manifold looks good so far, no water in and around the push rods and still none in the oil, i am crossing my fingers....the other head is off and appears intact....i found a head that "they" said is checked and has now cracks and does not leak.....i think i am going to try it and see if it will get me through the season and next winter pull the motor and get a new block and have valve jobs done on the heads just to be safe.......tell me what you think and thanks for the advice......
I'd take that Good head off your motor,+ Find 1 like it,... Whether it's the 1 you've found, or another,..... Take a Pair of heads to a Machine Shop,+ Have them Gone Thru.......Sharpen the valves,.. new seals,....<br />Bolt them on,+ Go Boating,..........<br /><br />What in God's Green Earth makes you Think you Need a New Motor ?????????<br /><br />Do the Head Job Now.......... Then You're Done......Go Boating,....... Have FUN...........<br /><br />You Got Very Very Lucky,........ Go Enjoy It,.........
BrettNC
What about the camshaft? Is that different or is it the same on the boat and trucks?
Huh,.................I Thought we were talking about Heads............<br /><br />It's Not Exactly the same cut,....... But, It's Plenty Close Enough to make Excellent Power,+ be Free from Reversion..........<br />Ayuh,..... The Cams.....
bauerterry
thanks bondo.....not me though asking about the cam....me just heads....and next time i will use my head and use anti freeze to winterize this thing thanks for all your help.......
KM2
You don't need antifreeze. You need to get all of the water out. I have that motor and draining it is fairly easy. <br /><br />It's my opinion that antifreeze is not needed and actual a PITA to get in and out of motor.
bauerterry
thanks km2......the problem is that there is no room, its a four winns 180 horizon and trying to get at the drain plugs are really tough.....i waited to long last year and now i am paying for it....i have seen that there are kits to winterize the boat with anti-freeze and like you being from minnesota, it gets cold even in the garage....hopefully that will prevent all this from happening again....all i want to do is get it on the water, now that the weather has turned nice again......
edfresh
New Boater -- I took my bad 4.3L OMC Chevy heads to a Car Quest machine shop and they decided it was cheaper to replace them with remanufactured "truck" heads. The guy used the GM number stamped on the head and sold me remanufactured "truck" ones with the same number (with new valves, etc.). They cost about $120 each. Quite cheap for two new heads. PS: The engine runs fine now.
bauerterry
hey i found remaned heads on ebay, they say for 94-2004, great price and wondering, should i match the casting number or what....any help will be appreciated......
Danm Flood Protection..........<br /><br />What's Going On Here,.............<br /><br />It Started Last Night,......<br /><br />Go to post,+ I get this Flood Protection page,...... Back button out of it,...<br />And My Post Is Gone........<br /><br />How Many Times To I Have To Type This Out.....????? :mad: :mad: :mad: :mad: :mad: <br /><br /><br />NBI,.... Your ebayers Must be Wrong,......<br />the heads Changed in 1996..........<br /><br />So,... 94 to 04 is Wrong...... Gotta be 96 to Date........
