4.3 back fires, bogs down stalls
ctak
Took the boat out the first time idled away from the dock and gave here throttle and a loud back fire then pick up and ran OK for the rest of the day. Next time out same thing. Back fired when first going out and then ran fine. 3rd time as I was coming in the motor just died while running at 3500 rpms. Started back up and ran fine to the launch. Went out yesterday and ran out to fishing spot.. tried to idle down and she would die. Started up and give her a little gas and engine would bog and die. Let sit for quite a while and tried to start up and had to give her 2-3000 rpms to keep her running out of gear. Tried to put her in gear and she would die. After playing w/ her for 5 min finally got her in gear and ran back to the launch at 3500 rpms. about a mile from the launch she dies. Start her back up again and make it back to the launch. I suspect a fuel filter or something in the lines but the back fire has me confused. Will a clogged filter cause and engine to back fire when cold?
Re: 4.3 back fires, bogs down stalls
Ayuh,... You have a Fuel Delivery Issue...
It could be as simple as clogged filters, or it's probably Crap in the Carb...
ctak
I pull the filter can and dumped the fuel into a class jar. It looks clean and clear. Just a little sediment. I'm wondering if there is a filter somewhere else.
Alpheus
Need some more info?
Year, or Serial Number...
ctak
This is on a 1994 Bayline 1850LS
Engine Ser. No. 0F076855 4.3 LX/V6 Alpha One.
chaparall villain 2
depending on what ignition it has it could also be thaat breaking down
docoakley01
Filter at the carb inlet good to check. Fuel quality overall, make sure the plug wires are in correct position are a few of the things I would suggest, particularly if you are new to the boat or plugs were recently changed.
ctak
I took apart the fuel line from the pump to the carb. Didn't find a filter at the inlet to the carb or around the electric fuel pump. There was the brass nut for the flare aluminum gas line that goes into a larger brass fitting that screws into the carb took both off and didn't find a filter. So now I'm scratching my head. The distributor was replaced late last year and once it gets on step it runs fine. I'll keep looking.
